For those of you using high-speed monochrome cameras: When you image using separate LRGB filters, how long do you capture a sequence for? On Mars, for example, I currently capture up to two minutes and don't capture any more because of planet rotation. If you are capturing four separate streams. Do you cut your capture time in four? Must you also quickly switch filters between runs?
Just curious.
thanks!
Steve
Just curious.
thanks!
Steve
