RICHARD COFER
Re: A few questions on imaging
Started by eabel, 01/17/2004 07:18PM
Posted 01/17/2004 07:18PM Opening Post
Steve:
Exposure comments:
Hi! I had a chance to borrow & use the ST2000 camera maybe 8 months ago and had a VERY difficult time with Planets. Their brightness overwhelmed that camera. I called SBIG to discuss it and was told that it really is a Deep Sky camera due to its sensitivity. Even the use of filters had minimal impact. I toyed with masking the C-11's aperture, but didn't take the time. Saturn, while a little less bright (Jup: -2.4; Sat -.8), is available. Try your hand also with the Orion Nebula.
You used an exposure time of .02 SEC; the camera's limit (if I am reading the specs correctly) is .01 SEC. Set it at the lowest end, filter it, and let us know the results.
Ed
Ed Abel
Silver Spring, MD
Posted 01/17/2004 09:51PM #1
Indeed Steve, seems your focusing technique is fine, but you are over-exposing your shots... faster exposures should do the trick... try 1/100, 1/50, 1/33 or 1/25 if it is still too bright. Also lowering your GAIN does help... (you don't want your GAIN to be at 100%, normally at 50-75%, maybe less if your image is bright enough)
You SHOULD see the Planet detail on your laptop/PC screen as you take these shots/movies...
Take care, and keep it up!
Ivan
smile
