Hi Eric -
I think your summary is correct, although it appears the new Imaging Source 21BF04 camera has significantly higher sensitivity. I am limited to cameras that can be controlled by a Mac using the AstroIIDC camera control application so will have to wait until that camera is supported to try it.
If you constantly fiddle with settings on your ToUcam like I do, you will appreciate the real time response via Firewire - and also the much faster capture rate and the large volume of sharp frames that can be gleaned during those brief moments of steady air.
Alan
Alan
Alan Friedman
