james carter
North American Nebula NGC7000
Re: Saturn on January 5th, 2005.
Started by Wes Higgins, 01/07/2005 01:28PM
Posted 01/07/2005 01:28PM Opening Post
Hi Damian,
Superb! image, excellent detail, glad to see you had some good seeing again.
I'm considering RGB imaging and I have few questions,
how many frames are in each color and what is the total capture time
including changing the filters and focusing ?
Clear And Steady Skies,
Wes Higgins
Posted 01/07/2005 02:31PM #1
Fantastic image. The rgb technique seems to capture very smooth color information. Could you give us a very general description of the work flow for generating Lrgb planetary images and any particular challenges it presents?
Also, could you post a single frame of the raw greyscale image ?
Thanks
Joe B
Posted 01/07/2005 11:47PM #2
Hi all,
Re: questions on filtered imaging.
For this image, i took a 300sec AVI for the L image using G+IR rejection (integrated light could also be used.) I then shot a 200sec AVI using the ToUcam for the colour. The L image is about 2500 images. This is by far the easiest way to do LRGB imaging with Saturn. However of course, it must be stressed that seeing is the #1 factor. As Eric's images show, the ToUcam can produce superb results also. What he mentioned on another thread about watching the weather carefully is very true - one has to be a meteorologist as well as an astronomer smile
For this image, the edge of the jetstream was about 300miles to the North, and upper winds dropped low enough to give steady images for a while. Now its back to 50mph winds at sea level sad.
Thanks for all your comments.
Damian
