Mark Eby
M33 Triangulum Galaxy
Re: Tackling Mars in IR - to pass or block?
Started by scifidude, 09/07/2005 04:24PM
Posted 09/07/2005 04:24PM Opening Post
Robert,
Maybe I'm ignorant about such things but just like in football I don't think you can "pass" and "block" at the same time. I guess the outcome is "unknown" if you stack an IR Pass filter on an IR Block filter.
Clear Skies
Weiman
Posted 09/07/2005 05:37PM #1
One of my Red filters has IR blocking and the other does not. I find that the images with the non-blocked filter tends to burn out in high red areas like Aethiopis while the blocked filter does not. If I used the non-blocked filter I'd likely use it with a blocking filter.
Paul
Paul Maxson
http://www.sunspot51.com
