This is my first Saturn after getting my scope cleaned so the collimation still needs tweaking. Previously, I had been using 140% gamma, however, the DMK recommendations have been to use a neutral 100%. I did not however compensate with enough gain and collected data at around 50-55% of the histogram. As a result, the rings were a little underexposed, and as Saturn climbed higher in the sky, I lowered the gain (not realizing it was too low already) and was not able to take advantage of the improved seeing. This RGB image was taken around 4:30am with my C11 & DMK21, below average seeing, best 400frames RGB, Dione faintly visible to the left.
Regards,
Steve
Regards,
Steve
