Saturn in B&W--weird lines?
Started by Mike Wirths, 01/30/2005 01:59PM
Posted 01/30/2005 01:59PM Opening Post
Hi all,
Tried to image Saturn the other night, the plan was to shoot the L vid then swap out the Atik B&W cam with the Toucam to shoot the colour portion. Trouble was that the seeing was basically really crappy, so I gave up at about midnight.
After aligning in Reg 2 and processing I noticed lots of vertical lines running through the image, this was apparent even in the stacked raw image. When I selected the avi I checked off the interlace box as usual, what gives? Is this effect caused by the really poor seeing? I did'nt get this effect when doing lunar shots (well I did if I pushed the processing too hard, but they were of much less magnitude).
still surprised me for really crappy seeing that it shows as much as it does.
-Mike Wirths
Mike Wirths's attachment for post 21871
Posted 01/30/2005 03:41PM | Edited 01/30/2005 03:42PM #1
Hi Mike,
In this case I'm not sure what caused the vertical lines but the vertical
line suppress in Imagesplus set to default settings pretty much took all
the lines out of your image when I tried it, you probably already knew that though.
Clear And Steady Skies,
Wes Higgins
Posted 01/30/2005 07:56PM #2
Hello Mike,
I have seen similar lines in my ToUcam and ATIK when the gain is set too high. At one time I had found a WWW page that discussed this in detail, but I can't recall where now.
Kirk
