Monday morning I had 4/5 seeing and 3/5 transparency good collimation and temperature control. With no filter I was easily able to see and capture Neptune's moon Triton so I knew conditions were above average. I slewed to Uranus and found it quickly with my 55mm eyepiece.
At f20, using my 1.8x barlow, Flea3 and the 685nm long pass filter, the image size and brightness seemed reasonable with a 650ms exposure and a slight 1.25x gamma boost. To make sure the focus was as good as possible, I closed down FireCapture and started Metaguide and adjusted until the best results were obtained. Then went back to Firecapture and collected 2500 frames, pausing every so often to tweak the centering. The lighter lower edge appears to be the southern polar cap, but the other shadings may or may not be real.
In hind site, I should have confirmed the orientation of Uranus with an unfiltered moon shot, but I plan to try again tonight in good seeing/transparency.
Regards,
Steve
Regards,
Steve
