Uranus f25, 9-11-06
Started by fugardi, 09/12/2006 11:13AM
Posted 09/12/2006 11:13AM Opening Post
Folks, With my Compustar C11 and a 2.5X barlow, I captured this image of Uranus as it reached it highest altitude approx 12:15AM in average seeing conditions. I was surprised to find it barely cleared the trees! Using my Toucam 840 with an IR filter, 1/25sec, 5fps, 50% br, 0% gam, 100% sat, 79% gain. I took the best 300shots from my 450sec avi and resized it by 2x. I tried adjusting the gain/gamma and found the best setup with no gamma at all but with a ton of gain. I have not subtracted the dark frame, but have one ready to go once I figure out how to do it. I did not use wavelets in Registax either but ran it through Neat Image 2x. I used my Kmart box fan to cool the observatory 2hrs before and during the session, and the seeing definitely improved.
Regards,
Steve
fugardi's attachment for post 33422
Posted 09/12/2006 11:20AM | Edited 09/12/2006 03:22PM #1
Folks, taken at Neptune's peak altitude around 10:50PM with Compustar C11, f10, and Toucam 840 with an IR filter, 1/25sec, 5fps, 80% br, 10% gam, 100% sat, 60% gain. Knowing how dim the planet appears, I did not even attempt trying a barlow. I took the best 300shots from my 450sec avi and resized it by 2x. No wavelets or color adjustment, just 1x through Neat Image. I finally got lucky and found it on the first try, switching from my 8.8mm eyepiece to the web cam.
Regards,
Steve
fugardi's attachment for post 107125
Posted 09/12/2006 01:49PM #2
20" box fan running full speed pulling the fresh cool air from the door across the scope and out the opening. This setup running for at least 2hrs prior to observing seemed to help my local seeing. The flow was very turbulent but effective. I still have my cat cooler on back order.
Regards,
Steve
fugardi's attachment for post 107126
