VDB 142 Elephant Trunk HOO
Use of Powermate
Started by Kevin, 03/14/2009 09:25PM
Posted 03/14/2009 09:25PM Opening Post
I use a 4x powermate for planetary imaging with my 1000mm refractor and also wish to use it with my D70, but am puzzled a bit with it's use.
When I got it, I thought I would be able to put it in the focuser, have the 1 1/4" adapter in it, and then put my web cam in for a "straight" imaging train. But it only seems to come to focus if I have the diagonal first, and then have the powermate. Even if I put the diagonal in after the powermate it won't work. When I put the powermate in then have my D70 after that It is nowhere near focus, and I can't even figure out if the camera needs to be closer or farther out. Obviously, I couldn't put it any closer to the powermate anyway that directly coulpling it.
Is there a photomultiplier out there that will let me have a straight imaging train?
Kevin
Posted 03/14/2009 09:50PM #1
The powermate is meant to keep things parfocal. That is, when you have an eyepiece in focus, and put in a Powermate, the eyepiece is still in focus (or very nearly so). If you put need your diagonal in the train with the eyepiece to get the eyepiece to focus, then you will need it in the train with the Powermate.
There are extension tubes that you can use in place of a diagonal. They give you the extra length of the diagonal, without the optics.
Posted 03/14/2009 11:51PM | Edited 03/14/2009 11:53PM #2
Here's what you need....
http://www.buytelescopes.com/product.aspx?p_id=4306&store_id=&did=4#
