Wizard Nebula
300D focusing
Started by brian11333, 12/10/2006 12:18PM
Posted 12/10/2006 12:18PM Opening Post
I'm having a focus issue with my 300D. I can't bring a star into focus with my refractor or my newt scope. The camera has had the IR filter removed and AF is off. Is there something that I'm missing?? I've used dedicated ccd cameras for a few years but I'm new to the DSLRs. I sure would appreciate any help.
Thanks
Posted 12/10/2006 02:37PM #1
As you are focusing, does the image almost come to focus and then you run out of focuser travel, or does it get close to focus and then out of focus without ever really coming to focus?
Posted 12/10/2006 08:27PM #2
Removeing the IR/AA filter should change the required backfocus only by some 0.2-0.3mm, which is unlikely to do much for your problem.
On the top of the camera body should be a symbol like a circle with a dash through it. This is the exact location of the focal plane/sensor inside it.
Try useing a (simple) eyepiece with a known location of its fieldstop & focus it.
Then compare the fieldstop location with the focal plane indicator on the mounted camera and you know if you can place it within range.
Michael
