Hi all,
For some time ago I bought a Canon DSLR 20D for my wife as she is really in photography. I being trying to get into Astrophotography kept it little out of sight as I regarded it for daytime only. On my last birthday my wife gave me a CD “Guide To Astrophotography with DSLR” and since then I have been trying to take images using the same. Tried with regular lenses for wider views to on my 8in scope using regular T-Mount adapter made by Qualide on a 1.25in focuser adapter. As most of the users of T-mount adapters know that this causes Vignetted image. Recently I upgraded the focuser to a 2in dual speed Crayford GSO type focuser from another AM member. To my surprise the adapter really doesn’t fit, it’s little wider than what I thought. The only solution was to pay for some standard adapter or upgrade to a really cool 2in to EOS adapter. After some thoughts I really couldn’t convince myself to pay for either and sell off the once that I have.
So I took the issue in my own hands. Took a ruler and started looking at the EOS to T-Mount adapter. The adapter comes in 2 parts; one outer ring, which has, goes in the camera and a ring insert with 42mm threads. To my surprise the outer diameter of the 42mm inner threaded ring is a thread (1/32in) over 2in! Walla, I need a 2in+ outer diameter pipe piece and it should work!
2in outer diameter pipe piece is very hard to find in regular Hardware store! I looked up online but the shipping charge was a few folds higher than the price and the actual piece. Well I decided it to my last resort. Tried to look in a few more HW store and everywhere I go some there will say 2in outer impossible! So my final trial was a used HW store and found a hard PVC 2in Coupling adapter, which has an outer diameter of just over 2in. They also had some steel once (may be now) but as I didn’t have a way to grind metal opted not to. To my surprise the adapter has an inner diameter of 1.8125in, pretty close to premium 2in adapter.
The next step was to grind the portion, which will go in 2in focuser to exact fit, paint black flat and attach to the EOS adapter and tight halfway the 3 tiny screws.
Hope the images helps anyone who might try to make their own adapter.
Ansuman.
Ansuman.
FluffyDuck observatory
Celestron 8N/CG5 NON GOTO
Canon 20D, Neximage,MX516
Losmandy G11 GOTO
