Wizard Nebula
DSLR Choices
Started by Kevin, 02/17/2008 04:32PM
Posted 02/17/2008 04:32PM Opening Post
I have a few questions for the group on DSLRs. First, is there a way to process out amp glow from a D70 when pushing it to higher ISOs? I am sure there probably is (dark field sub?) but not sure how this is done if you have a DSLR. I am familiar with doing it in AIP for ccd fits files or with automated functions of SBIGs software, but haven't a clue for dslr JPEG images.
Second, What is the latest best choices on a budget? I would get a body only for astro use. I have a D70 that seems to work great for daylight. XTi? 40D? Is a 20Da the premier camera or one of the newer standard cams with live view?
Third and last, whats the best XT/XTi mod for astro only through a APO?
clear skies,
Kevin
Posted 02/17/2008 06:58PM #1
With your D70, have you tried shooting with the long exposure noise reduction function turned ON? The camera does a good job at getting rid of the amp glow. It basically takes an identical exposure without opening the shutter to capture just the glow, then subtracts the results. The whole in-camera noise reduction process my eat some of the very faint stars, mistaking them for noise. I have had a lot of fun shooting DSO's with my D70, but most of the folks here will tell you to get a Canon, modified of course. Forget about the budget, though. If you are still new at this, there is a lot you can do with that D70. In my anser to your next post, I suggest software for subtracting dark frames from your JPEGS.
Steve
Posted 02/24/2008 02:25PM #2
clear skies,
Kevin
If you're serious about astrophotography, think "Canon." They produce decidedly lower noise images and there is none of that "mode 3" stuff to worrry about. Might want to wait for the new 450D to come out. If nothing else, that should cause a price drop on the 400s. I've got a 400D, my first DSLR, and I'm impressed enough that I'll likely be adding a modded 40D body to the stable when I can.
8)
Uncle Rod
Time on your hands?
