Ok, what I have: GPDX, Canon 20D, Orion ED80. Need some pointers. Lens I have for the 20D: 70-200 2.8 IS, 50 1.8, TC 1.4x, and a 18-55 kit lens 4.5-5.6. Need some pointers to get started, thanks!
Got me a GPDX!
Started by Grumpy_one, 08/31/2008 06:25PM
Posted 08/31/2008 06:25PM
Opening Post
Posted 09/01/2008 12:06PM
#1
Assuming you have a "dovetail" plate for the mount, it should have one hole in it that will accept a 1/4"--20 thread screw of the appropriate length to stick into the bottom of your 20 D. Get a rubber (or cork) washer to stick between the camera and the dovetail, screw the camera onto the dovetail, mount the dovetail onto your mount.
Polar align the mount and start it tracking.
Point it to Saggitarius or Scorpio, and use the 70-200 mm zoom. Put the camera on Manual exposure at 30 seconds. Set the aperture to one stop slower than full aperture. ISO to 800. Large/Fine jpg's for quality. Set the camera to use the self timer. Set the custom functions to "Flash does not Fire." Focus and frame as well as you can looking through the viewfinder. Push the shutter release. Do that three or four times on the same subject.
If you have a remote release, you can change the part about using 30 seconds and the self timer to use whatever exposure you want.
You are started.
It does get more difficult that that, I should say, though.
You are started.
Funding Member
