Infrared Digital Camera
Started by dchavezjr, 04/01/2009 01:00PM
Posted 04/01/2009 01:00PM Opening Post
Hello to all,
I saw an ad about a Canon EOS 20D digital camera, the ad states:
"It has been modified/converted to an infrared (IR) digital camera by a professional. The hot mirror (IR blocking filter) inside this camera was removed and replaced by an IR filter (with 700nm Cut-Off at 50% transmission rate). It has been re-calibrated to ensure the autofocus system works properly after conversion."
Can this modified camera be used for astrophotography?
Thanks in advance and clear skies,
Junn
Riyadh, Saudi Arabia
Posted 04/04/2009 11:56PM #1
Not for general purpose astrophotography.
It's filter passes *only* IR, not any visible light.
Another side effect of this modification is that it effectively is B&W
only, at IR wavelength all pixels have about the same sensitivity.
For astro you'd most likely want to convert it again and put
a visible light + Ha (very deep red light) filter in there.
Michael
