M42 region luminous version
Started by ivanong, 03/02/2006 01:51AM
Posted 03/02/2006 01:51AM | Edited 03/03/2006 01:38AM Opening Post
Hi All, This was processed to bring out the luminous quality of the nebula. This is a painstaking collation of exposures from 7 min all the way down to 15 sec with an unmodified 20D at ISO 1600-800, IDAS filter and an A-P 130 EDFS at f/4.5. The alignment and combination sequence was quite tedious but it gave me a wealth of data to work with- and a very 3D wealth at that, kind of like doing water colors where you build up layer after layer. I still like the reds in the unmodified 20D's- the extra sensitivity at 656nm of the modified versions is a little too strong on the pink/magenta side, but I suppose I'll get used to it when I purchase one.
Thanks for looking! Ivan
ivanong's attachment for post 30069
Posted 03/02/2006 02:02AM #1
Wow Ivan. Magnificient! Your best yet IMHO. Thanks,
Dan
Posted 03/02/2006 02:22PM #2
Simply beautiful, Ivan.
Thanks for all your hard work and posting this.
Jeff
Posted 03/02/2006 02:57PM #3
Ivan: Great picture! It rivals those I've seen with much more expensive equipment. And, from an unmodified 20D. Simply spectacular
Posted 03/02/2006 07:45PM | Edited 03/02/2006 07:45PM #4
Beautiful work Ivan... 8)
I fully understand when you say this was a LOT of work... M42 is probably on of the hardest objects to show in its FULL Glory...
Posted 03/03/2006 03:26AM #5
Nicely done Ivan.
You managed to tame the wide dynamic range quite well.
Robert
Posted 03/03/2006 02:41PM #6
