Ruben Tommasi
Andromeda Galaxy (M31)
500 mm lens question
Started by richardpeters5, 02/27/2003 06:36PM
Posted 02/27/2003 06:36PM Opening Post
I just picked up an inexpensive (used), 500mm lens. I got it just to fool around with because it was cheap. But without sounding too ignorant here. What is the O<-->C dial for on the lens, and what do I do with it ? It appears to stop it down internally?
Rich
Posted 02/27/2003 08:14PM #1
That's what it do! You "preset" the other ring to the f/stop you want, then turn the O-C ring from O to C to take the picture. At O the image is brighter for focus.
If you are using with a camera that has Shutter priority metering you can put the click ring to a large number, say 22, and turn the other ring until a shutter speed lights up that is appropriate for the situation.
Walt
Posted 03/06/2003 01:27AM #2
While we're on this subject, what would this lens be used for primarily? Brian
