Jay Messeroff
Lunar & Solar Transits
Attention Paul Hyndman!!...re: projection
Started by barf, 01/27/2003 12:29AM
Posted 01/27/2003 12:29AM Opening Post
Paul, the moon shot you took and showed us on this forum...was that taken as eyepiece projection and if so...how close was the Nagler eyepiece to the CCD?. I am finishing up on an eyepiece adapter to try projection in the upstairs window planetarium.
Consistant with cutting edge technology :-) I will use the Southern window and try for the 30 to 75 degree elevation of the moon and planets. The 15-30 degree East imaging is hopeless.......to much pertebration in definition. LarryS.
Posted 01/27/2003 11:10AM #1
Uhhh... if you are referring to the triple panel shot:
http://www.astro-nut.com/interact.html
Those were from a 5" Tak' with a Nikon CoolPix995 direct-coupled to a 31mm Nagler Type 5 eyepiece. Since the lens of the Nikon CPs are not removable, afocal is the only method possible. I used a close-coupled Televue adapter that screws into the camera's filter ring:
http://www.astro-nut.com/adapters.jpg
This close arrangement allowed the camera to be used even at 1X (no zoom) without vignetting, though the zoom was used to produce the three different image sizes seen there.
Even though forced to use afocal methods, the Nikon CP was pretty good for Lunar shots:
http://www.astro-nut.com/gibbousmoon.jpg
The shot below was with the same scope, but with a Canon D60. As an SLR, it does not require afocal methods, and was taken at prime focus (no eyepiece, Barlow, Powermate, etc).
Paul
pghyndman's attachment for post 64553
