CCD fan WARNING et.al.,
Started by barf, 01/14/2003 07:56AM
Posted 01/14/2003 07:56AM Opening Post
In the process of designing my 675K CCD housing I decided to test two 12V. ball bearing fans of the type used in computers.
A Socket 7 type, (more blades & air flow) for the larger processors had a distinct STRONG vibration under 100 hertz.
A Socket 3 type, (less blades & lower air flow) had a significantly reduced vibration but still strong enough to be easily felt by hand.
These vibrations of low frequency could easily degrade image quality if transmitted into the focus tube and telescope.
It might be wise to check image quality with fan on and off to see if the fan is causing reduced definition and contrast.
Of further note....most of the heat in the Philips Vesta PCVC675K is coming from the large processors on the piggy back assy board, NOT the CCD. This was a 1 hr. test with moderate illumination & heat sinking the CCD to the metal case via a cut-off metal mount which was a part of the original LED/Microphone/Lens front piece. The case was left open to isolate source of the heat. The heat sinking of the CCD did NOT increase case temperature in its vacinity.
I am a beginner, so these are for what it is worth. -LarryS
Posted 01/15/2003 06:17PM #1
Larry,
you might want to research the fan producer Pabst. They are well-known for their extremely silent fans in the audio industry. The silence does come from the proper air flow and by a proper balance of the wings and precise bearings.
I have a 12 Volt one and it is *very* silent and without vibes.
CU
Tom
