-The following information is offered for those like myself that prefer to make their own equipment rather than buy ready-made *overpriced* in a box.
-This photo included, shows the adaption of a cheap RA 9V. clock drive to a focuser shaft on a telescope. It does require redrilling the coupler to accept the large size focus shaft.
-First trial test indicate the motor DOES NOT transmit any mechanical vibration to the telescope even at large powers.
-The focusing is slow granted....but this is what we really want for critical adjustments right?.
-I found it was easy enough to reverse the motor and stop the motor without adding an extension box and cable to do those controlling functions. I may add them anyway.... I did add a remote control. Works great!.
-The only drawback to this quick and dirty system is....you must focus closely first before tightening the set screw....and the setscrew should be in the middle of a convienant spot which is set by the motor. This is so you can go both ways with the drive control. I may notch the mtg. plate to allow full rotation of the setscrew..."Maybe".
-I used two of the BOTTOM screws of the focuser worm-gear cover plate to secure the plate. -LarryS.
(Incidently- the taped Logitech mess on the tube is for trial purposes...not the planned real stuff in this "upstairs" observatory.) :-)
