Iris Nebula
Scanning Film vs. Digital
Started by Ghambit, 11/12/2004 09:06AM
Posted 11/12/2004 09:06AM Opening Post
Welp, yes, I'm bringing this up again. Only because the winter season approaches, I'm breaking out my scope and my OM-1 and visited my local photolab. Come to find out they have the capability of outputting drum scans up to 500mb medium format files, pretty cool.
Anyways, I was wondering again about the actual benefits of CCD over film when it comes to resolution. Someone correct me if i'm wrong please, but the latest Canon 20D shoots a max resolution of about 3500x2300 (8.2MP), bit depth of 12 across the board, saves in RAW and JPG, and has a film plane of 22.5x15 mm. A cheap Epson photo scanner does about 4800x9600 dpi (with interpolation 12800 x 12800) has 48 bit color and 16 greyscale, can output in multiple high quality formats (JPG can cause noise and artifacts), as well as scanning 35mm and med. format which is innordinately larger. 200 bucks for scanner... 1800 bucks for 20D.
It seems to me the more I analyze the market that with every new digital camera there is also a marked increase in scanner technology (makes sense since they both largely use CCD). With the limitations of film basically limited to our ability to process the info. on it (i.e. scanning and/or interpolating it)can there ever really be a doubt as to which is the better medium?
Im really asking this because I'm thinking about purchasing a scanner and getting further into 35mm and was wondering if I should just bone up and drop some coin on an expensive CCD.
Posted 11/12/2004 03:03PM #1
I've asked the same question......
I believe you can still get more pixels with film than you can with anything digital. (Anything we could buy, anyway.) You can also get a wider field. So, if it is simply an issue of resolution--number of pixels per square millimeter-- then I'd say film is still superior.
However, imaging is a lot more than pixels. You have to track a lot longer for film than an equivalent ccd exposure. It is much harder to focus a film camera than a digital. With a film setup you don't know what you did until much later. With digital, you can reshoot then and there if need be.
SO, get out the OM-1, (I plan to do so tonight and tomorrow if the weather allows). However, I don't plan to update my scanner. I'll just save my pennies and go to digital.
(Besides--I want a DSLR for daytime use.)
Posted 11/12/2004 04:43PM #2
Hi Shawn,
I am by no means an expert in photography, astro- or otherwise. But, I've been considering getting a DSLR to replace my ageing point-and-shoot digital camera. While doing the research on the Nikon D70 I came across this website:
http://www.kenrockwell.com/tech.htm
Mr. Rockwell is not an astrophotographer, but his articles about film vs. digital resolution and the megapixel myth (in the consumer p+s cameras) I thought were very well done.
Hopefully this site contains some information you might find useful.
Regards,
Louis Marchesi
New London Township, PA
Regards,
Louis Marchesi
[COLOR="Gray"]New London Township, PA[/COLOR]
