Philip Imbrogno
Elephant Trunk Nebula
Slides or Film?
Started by Astronomer2b, 07/16/2002 10:21PM
Posted 07/16/2002 10:21PM Opening Post
Since i started astronomy i have been using Fuji superia 800, with some descent results, but im wondering would slide film give better results? I am out of film so when i resupply i want to get whats best. Is it cheaper to buy and process slides or flim?
Thanks
Posted 07/17/2002 01:26AM #1
Slide film is typically more expensive than negative film and costs around $7-$9 to process. Kodak E200 seems to be the best by for pretty much everything, I've had great success with it, while Fuji Provia and Velvia seem to do very well of blue objects like comets.
The problem with slide film is that it has less dynamic range than negative film causing brighter stars to have burned out cores and less extended detail in faint objects. While fancy processing techniques can fix this, it isn't as good as negative film. Also, you will normally have to push slide film to get nice density unless you have exposures greater than 40-50 min at f/5-6.
As for negative film Fuji 800 in my opinion is less than ideal. When I shot it a year ago it had little red response and the color balance was very poor. Reciprocity was also quite bad. I've been using Fuji Super HQ 100 lately and have been very happy with it. It's red response could be better but it seems to have almost no reciprocity. The grain is very fine for color film and has great dynamic range. It's also very cheap, you can get a 4 pack for about $7. Kodak has discontinued all of it's good films (PPF PJM and PJ400) but hypered Royal Gold 200 is turning out great stuff lately.
My advice, pick a few different types and use a roll of each on similar objects then compare them to see what you get.
Daniel
http://home.earthlink.net/~dreyna14/astro.htm
