antenna question
Started by dale tubbs, 02/08/2004 11:04PM
Posted 02/08/2004 11:04PM Opening Post
ccrane company has a flexible 15.75" antenna and a 15' coax antenna. Both are 24 dollars. would one of these be a great improvement over the 7" "rubber duck", I guess they call them, antenna that came with my pro42 scanner? thanks.
Posted 02/09/2004 03:48PM #1
Dale,
I'll answer again with a very broad rule of thumb. Just as aperture rules in astronomy, capture area rules in radio reception -- the longer the antenna the better (more capture area in a longer antenna). It's like using a big net vs a little net when casting for bait. So I'd go for the 15' coax antenna rather than the 15.75" flexible antenna, especially if it can be mounted outdoors. For best results, be sure to mount the antenna vertically since most signals you'll hear on a scanner are vertically polarized.
Jim WD5BKO
