listening with scanner
Started by dale tubbs, 02/04/2004 09:00AM
Posted 02/04/2004 09:00AM Opening Post
Is it ok to listen to HAM transmissions with a scanner. If so could someone tell me what frequencies to listen to , and do you need a special antenna, or will the little 12" one on my scanner work? Thanks.
Posted 02/06/2004 04:22PM #1
Hi Dale,
Yes, it's OK to listen to ham radio communications on a scanner. Many hams get started that way. As for the frequencies, it depends on where you live. Very simply stated, most ham radio activity takes place within two broad frequency spectrums. The long-distance (including world-wide) communications take place in the high-frequency (HF) range, on several slices between 1.8 MHz and 30 Mhz. These frequencies require longer outdoor antennas, although a fairly short -- 20 feet or so -- indoor wire antenna will work for receiving only. Most of this communication takes place using CW (Morse code), various data modes which require special equipment (sorta similar to a modem) or software to interpret, or on a special voice mode called single side band (SSB). Some scanners have the capability to recieve SSB, otherwise, the voices all sound like Donald Duck.
If you live in or near a city of any reasonable size, there's probably a lot of ham activity on the very high frequency (VHF) bands. The most popular of these is the 2-meter band, which lies between 144 MHz and 148 MHz. 99% of the hams on this band use voice in the FM mode, and transmit through repeaters (remote automatic relay stations). Repeaters are typically located on tall buildings or mountain tops, where they extend the range of the typically low-powered VHF/FM radios. This is because at VHF frequencies, the radio waves are usefull only to line-of-sight distances -- since the repeater is high up, it can "see" farther than a person on the ground. Program your scanner to scan at 15 KHz intervals between 145 and 148 MHz and you're sure to hear some hams, especially around rush hour in the morning and evening as they chat on their way to and from work.
More information on frequencies and ham radio in general can be found at www.arrl.org.
Good luck,
Jim WD5BKO
