Wizard Nebula
C 8 Owners: Have you incountered this problem?
Started by Midnight Sun, 12/24/2003 12:13AM
Posted 12/24/2003 12:13AM Opening Post
I recently installed a 6.3 f/R at the rear cell of my Celestar C 8. then I threaded to it my 2" AP adapter followed by my 2" Everbrite dia. & Finally my Pan. 35. I then tried to position/aim the scope towards the Double Cluster in Per. which at the time was high overhead in the NW. "No could do!" the mirror housing on the Dia. came into contact with the R.A. clamp down on the tilt plate. Too much length! had to remove the focal reducer so I could swing towards the Zenith. I figured this scope was intended for use with a 1.25" diagonal. Am I correct? I have the shortened version on the TV 2" dia. Maybe if they made a shorter adapter I could "swing it".. your thoughts.. JM
