C14 Lift
Started by mogan, 10/08/2011 10:17PM
Posted 10/08/2011 10:17PM Opening Post
I'm thinking about purchasing a C14. Is it realistic for one person (me) to lift this babe from storage to mount without slipping a disk? I'm not a body builder.
Input is appreciated!!
Canon 600mm L/4.0
Canon 1dMk4
Canon 1dsMk2
Canon 1v (35mm film)
AND A TON OF OTHER PHOTOGRAPHIC EQUIPMENT
AP Mach1 (on order)
MV AGUSTA f4
'00 Lafite Rothschild
Posted 10/08/2011 11:58PM #1
Hi David; here's a cute couple of YouTube links that you might find useful regarding manhandling a C14:
http://www.youtube.com/watch?v=TBawz69qo_A
http://www.youtube.com/watch?v=IwVg1M6bURI&feature=related
Randy.
Posted 11/01/2011 06:41AM #2
David....I have a C-14 and the old fork mount. I am 5'8" and weigh 150# ...I can mount it on the fork asm...not impossible(ha,ha) and is douable but not super easy. I also have tried mounting it on a G11 and it's not as bad because you don't have to lift as high. Gerry
Posted 11/06/2011 02:18AM #3
David, I did it for a couple of years. First with the forks (big pain but doable) and then on a GEM (much better but not trivial). I found myself only taking it to dark sky sites when conditions were excellent. I sold it, primarily due to weather here in New England being marginal most of the time and dew being difficult to deal with. Now my TEC 140 seems easy. If you can easily lift 65 lbs over your head several times, you'll probably be OK. If you struggle with a barbell of that weight, you should reconsider your plans.
George
Posted 11/26/2011 02:39AM #4
It's possible. Get on Youtube and have a look at Greg Nowell's C14 videos.
Uncle Rod
Time on your hands?
