Wizard Nebula
Celestron Service/CN16 GPS/CG-5 goto
Started by Rod Kaufman, 07/27/2009 05:23PM
Posted 07/27/2009 05:23PM Opening Post
I recently purchased a CN16 GPS unit with auxillary port and hooked it up to my CG-5 advanced series GT goto mount and it doesn't work. I've turned the GPS unit to the "on" position in the handpaddle after I've leveled the mount, polar aligned it, entered the index marks, etc. I get a message (which I believe is the correct message) stating, "searching GPS" followed in a few seconds by "enter auto three star alignment" which I also believe is correct. However, the mount then slews to the alignment stars which are'nt close to where they should be.
Floyd Blue has previously helped me enter time, date, place etc manually in the field and the goto has worked just fine. I bought the GPS unit so I don't have to enter everything manually and also because the alignments are supposed to be more accurate.
I got the GPS unit on Saturday via Fed Ex and tried it Saturday night from my home in Castaic. As it happened, I had excellent transparency and seeing, so much so that I could see a great deal of the milky way despite suburban light pollution. After numerous checks, rechecks, and power-downs and restarts, I somehow got an accurate three star auto alignment and I was able to continue to observe to 2:00am, pulling in brighter planetaries, galaxies, and clusters with my antares 6" f6.5 refractor on the CG-5 goto mount but I have no idea of why the last attempt was successful when multiple previous attempts were not.
The poorly-written one page instruction sheet that comes with the CN16 GPS unit simply covers installing the unit on the mount/tripod with one note telling you to turn the unit on in the handpaddle. The sheet refers you to the owner's manual of the mount for "detailed instruction on GPS assisted alignments". Trouble is, there are no detailed instructions with the mount on GPS-assisted alignments, either with the manual that came with my mount or in the updated manual(s) online in the Celestron website.
The version of my handpaddle is 305 and the current version is 4. something or other but there's no indication if the firmware has to be updated for the GPS unit to work.
I called Celestron support this morning and, after being put on hold and listening to elevator music for twenty minutes, I gave up on their non-toll free telephone line. I've placed an email assistance request available on the Celestron website and I'm awaiting a response.
The whole thing has been very frustrating, especially since I was led to believe the CN16 GPS would be a plug and play item...
Posted 07/27/2009 05:40PM #1
Rod, I don't have that external GPS unit, but how long was the GPS 'turned on' before you try the GOTO?
Lots of budget GPS take many minutes to figure out where the heck they are, especially the first time they are powered on after being moved hundreds of miles. Maybe the expensive ones are the same, but have never used an expensive one.
Before doing alignment on the CPC (with built-in GPS) I wait quite awhile then always go into the setup screen to verify that the mount has correctly figured out its location and the correct time.
Posted 07/27/2009 06:11PM #2
Rod: About all I can suggest is to try to reset the mount to it's defaults and then see how it works. It is my understanding that these mounts do some learning and have that in the memory. Resetting it maybe allow for a fresh start. I believe that function is somewhere in the utility menu.
Just a shot in the dark.
Posted 07/27/2009 07:49PM #3
Hey Rod,
Did you get one of these?
See pic
jmclaugh2001's attachment for post 131592
Posted 07/27/2009 10:01PM #4
Rod,
I just purchased one of these units to use on my Nexstar 8SE mount. It took quite a while for it to acquire satellites. My Garmin GPS does the same thing, BTW. When I am going to go out and observe I turn the mount on and let it sit for 10-15 minutes or more prior to when I start the alignment process. I get a message that the GPS is linked when it does its thing. When I set it up for the first time, I had a similar situation as yours. I think that you probably had a timing issue and need to give it a chance to link. And what someone else said is true .... if it was flown across the country it takes a bit longer the first time to get settled. That was in the instruction sheet I received with this unit (which I will agree is sparse at best!). The GPS link up is not instantaneous and the mount will still prompt for the 1, 2 or 3 star alignment, even before the link is completed.
Hope that helps!
Posted 07/28/2009 05:27AM #5
Celestron tech support emailed me this afternoon to inform me of the following:
1. New GPS units take 30-40 minutes to link up the first time.
2. Thereafter, they link up in 2 or 3 minutes.
I tried the unit again tonight and all is apparently well as my auto 3 star alignment happened without a hitch and the goto functioned as it should. I wish my instruction sheet had included the information supplied by the Celestron tech-support.
Thanks to all who have taken the time to provide their input in helping me solve the problem.
