RICHARD COFER
East is west
Started by Protious 1, 11/21/2012 12:57PM
Posted 11/21/2012 12:57PM Opening Post
The last couple times I've turned on my RG-5 goto mount and selected Jupiter, The mount goes in the opposite direction. I ck,d. Time site and every seems to be set up correctly. Any suggestions? :C :C
steve dejarnette smile
Posted 11/21/2012 09:07PM #1
I don't have your mount, but I have a CPC-800. I have found that low battery charge will make the computer do stupid things. Also, I had a power cable (non-Celestron) on a home-built battery system that fit just a bit loosely into the power socket and that also caused strange behavior if the plug was even slightly touched.
Posted 11/21/2012 11:05PM #2
To add what Fred said ,also ck to make shure it's set to northern hemisphere if that doesn't work do a factory reset, spread the center pin a little with a jewelers screwdriver and see what happens.
Good luck keep us posted.
Pete
