mount pros & cons ?
Started by Midnight Sun, 01/23/2010 08:40PM
Posted 01/23/2010 08:40PM Opening Post
Trying to see what mount works best for the Celectron 11" SCT. I the Nexstar uses the double arm yoke type design, where the CGE mount is more like the German EQ design. I used to have the older "Wedge" type mount I used with a C8 scope I did not like it, especially when viewing high twards the zenith.. conflicted with my diagonal/ep position... thanks for any suggestions ,John M
Posted 02/09/2010 07:26PM #1
Are you just going to do visual observing? If so then the fork mount is easier setup, and better eyepiece placement for visual observing.
The GEM is better for photography.
LX90 8" LNT, Celestron 80mm-guide scope,
ETX 90, and 20x80 binoculars
Posted 02/10/2010 01:06PM #2
What do you want to do with it? Imaging? Visual only? Mix. The CGE has been discontinued, BTW.
Uncle Rod
Time on your hands?
