Newby with an Orange Celestron 11
Started by shorton, 08/31/2006 07:54PM
Posted 08/31/2006 07:54PM Opening Post
Hello Astronomers!
I just happened-across an old Celestron 11 scope at an estate auction nearby, and I was able to get it for $85. See below links. While I was hands-on and used a C8 and C14 quite a bit in college, that was 15 years ago, and I have hardly had time to look up since then. Well, I have small kids now, and when I saw the scope at the auction, I started having all kinds of visions of daddy-daughter nights looking at the stars.
This equipment is quite filthy on the outside, but looks pretty good inside. The fork bushings (bearings?) are pretty stiff. I posted here hoping to get some advice on the how to get up and running. Can anyone help?
1. I'm a bit afraid of the anti-glare coatings, so I'm hoping to find someone who can do a complete, professional tear-down and clean-up on it. Are there any shops for this local to the Dallas, Texas area? Or, is it a better idea to send it in to Celestron?
2. As you can see from the pics, all I've got is the OTA, forks, sighting scope and wedge. Can anyone suggest where to get a right-angle plus lenses? How about a tripod? Is there a protective case?
3. Are there still parts available to upgrade to a motorized mount? What about adding GOTO for this guy? Can anyone suggest sources and costs?
Thanks for the help,
Stephen
shorton's attachment for post 33213
Posted 09/01/2006 01:04AM #1
1. I'd suggest sending the whole thing back to Celestron for a cleaning, collimation, and mount re-greasing. There are others who will do it, but why not go back to where it was born smile
2. Equipment, well right here of course silly. Amart for used stuff, or Anacortes for new.
3. Sorry cant really convert those mounts. You can buy a "push to" DSC set up though. Of course you can always remove the OTA and put it on a different mount....
Posted 09/08/2006 02:53AM #2
Let's see the front of the scope (corrector) upload a picture. My guess is it's fairly clean.
You can remount the scope back on the fork easily and use as is on the wedge to first see if the optics are any good (should be fine) and then decide if you want to send it to Celestron. Most cases cleaning is not hard to accomplish especially if the outside is all that is needed.
Again let's see the corrector.
Greg
Posted 09/18/2006 08:01PM #3
Hi folks,
Thanks so much to everyone that has replied. Something's wrong with my digital camera; otherwise, I would have replied sooner with pics down through the corrector. BTW, the corrector looks pretty clean, although the cork seal appears to have shrunk and is coming out around the edge. Looking down into the tube, the primary mirror is pretty dusty, but it just looks like dust (no grime or anything else to indicate that moisture got in there).
I sent an email to Celestron to inquire about having it cleaned, and asking about availability of accessories. Celestron replied saying that they would charge $200 + shipping to clean and collimate it, and that I should send back my personal information to initiate the return. Since then, I have sent Celestron several emails with the requested info, but no reply (I did check that my support ticket on their web page was getting updated--it is). Kinda frustrating... Does everyone else have this kind of response?
I wanted to ask you kind folks for some more advice... Since posting my original message, I've been casually browsing the forums and classifieds here, as well as other resources on the web. I'm trying to put together a decision matrix for my options on the mount and tripod--I want to weigh cost, availability, and feature/functionality. So far, I am totally overwhelmed with all of the brands / models of stuff out there, and furthermore, I can't even tell which tripods (and mounts) are sufficiently sturdy enough to hold up this heavy scope. Does anyone have a couple of minutes to post a list of options (from your opinion) that I could go with to complete my setup? (I am imagining something like: Option1 (least cost): Add heavy wooden tripod to existing mount, Option2: Find a permanent pier (not likely since here in Texas, the ground moves often)...... OptionX: Losmandy stuff, Meade stuff, Vixen stuff, Celestron stuff..... OptionZ: Nice Goto mount with Tripod. I hope its okay to ask this question in this forum instead of the mount/tripod forum...
thanks for everyone's patience,
Stephen
