Replacing or repairing Ra/Dec Cables
Started by SLAV, 01/31/2005 06:15AM
Posted 01/31/2005 06:15AM Opening Post
Hi
I have a Polaris Drive Controller for my CG-5 mount that needs both cables replaced. The cables look like the kind used on telephones. The problem is that the plastic clip that locks and releases the cable from the motor has come off. Any ideas on how to replace or fix it. The model # of the hand controller is 93820. I like using it because it uses only one 9 volt battery. Anyhelp appreciated.
Slava
Posted 01/31/2005 10:34AM #1
Any Radioshack should have the tool you need to install new plugs. The local store has an inhouse one they use for little jobs as a courtesy.
