Wizard Nebula
To sell or not to sell....
Started by Wolfstar, 12/16/2008 07:54PM
Posted 12/16/2008 07:54PM | Edited 12/16/2008 08:01PM Opening Post
Mentioned this in passing in the Mounts forum, but I really could use some advice.... Xmas is coming, my wife says I can get the mount I want (Cg5)...here is the question. I have an Ultima 8, nicely accesorised (sp?) WO 2 speed focuser, Astromaster, Starizona counterweight system, 9x5 illuminated RA finder, piggyback camera mount. If I get the mount, I will definitely ( try to) sell the forks, with DSC and counterweights. However, I am also looking at selling the whole shebag instead and opting for a WO zenithstar 80 to mount with an Orion ST 80 (for autoguiding) on the Cg5. I am looking primarily at astrophotography with a Cannon EOS Xsi. I have never sold anything here before, and am looking for advice as to what the Ultima Fork, with DSC and counterweght setup is worth, or what to whole setup is worth. If I don't sell the C8 ota i would mount it with the ST80. I would like to go lighter, so the moiunt has an easier time, along with my arthritic back wink
PS, the sale of the whole shebang might also include a WO Binoviewer with ep's
It is what it is...
Posted 12/16/2008 08:15PM #1
Hi Tony,
I would just like to say, I hope you enjoy the photography, it is a lot of fun. grin
The mount is the heart of the photographic setup. It must track steadily for you to get any results. The tripod or pier is a big part as it must help in dampening the vibrations induced by wind, motors or whatever.
The mount head itself must also be able to handle the load without any issues. Then it must have PE that is controllable with guiding. The load (weight) is one of the factors in this, but the inherent PE of the mount from gears, worm and motors is also a factor.
Be sure to research this well or else you may not end up with what you need.
The real problem is that the cost of equipment is directly related to all of these qualities. The expense of buying a better quality mount for instance, is 2-3x that of a lessor mount.
The same is true for the scopes of course.
So think about the purchase and consider all these factors and then make your decision after you have researched it well. This will save you money in the end. smile
Posted 12/17/2008 03:12PM | Edited 12/17/2008 03:12PM #2
You have the Ultima fork I take it the bigger heavy duty fork tines that was made in the mid ninties? You have something like a 6 or 7 inch worm gear in the base. If this is correct have you tried to do Astro-Photography with this setup. If you have the fork I'm thinking of, I don't think the CG5 is going to be your answer. If you were upgrading to an Astro-Physics Mach 1 goto then yes that would be an upgrade. Personally I would keep your Ultima 8 and use that for your photography
Dwight L Bogan
Posted 12/17/2008 03:30PM #3
I was kind of in the same boat a few years back. In the end I did not sell the U8 forks because I didn't need the money and I couldn't bear to part with them. Eventually, an 80s vintage C8 OTA fell into my hands and a put it on the U8 fork and even use that configuration occasionally. As for as the OTA? I've done a hell of a lot of imaging with the U8 OTA on the CG5. I've also done quite a bit with a WO 80mm I like both for different subjects. I'd advise holding onto the C8 and purchasing an ED 80 to go with it to serve as both imager or for guidin the C8.
Uncle Rod
Time on your hands?
