As some may know I had several spiders inside my scope messed up the inside of my lense forcing me to take out the objectives and clean them.. All that is done and everything is back together but something is not right. A star test shows an oblong circle which usually means astigmatism, which leads me to believe I didn't align the two lenses together properly.. ( I tried loosening and tightening the retaining ring which didn't seem to help )
1. Is there an easy way to just rotate the top lense without taking it all apart again? ( Maybe loosen the retaining ring and move with my hand wearing latex gloves?)
2. Is there some type of false star I could set up say 20ft away so I could test and know if at least I'm headed in the right direction?
3. I did collimate so that only one reflection was showing but I did it by adjusting the focuser..
It originally tested with a good circle before I took it all apart...
Any help would be appreciated....
