Wizard Nebula
Mounting rings for 10" LX200 GPS
Started by buzzman, 08/29/2006 01:27AM
Posted 08/29/2006 01:27AM Opening Post
I want to piggyback a William Optics 66mm Zenithstar Petzval refractor OTA, also I have a ZenithStar 80 that will pull dual duty as a guidescope and a grab-in-go. I would like to know what the best way for mounting these two scopes (not at the same time)on my 10" LX200. Would I need to a counterbalance? Please help point me in the right direction, I have the newer LX200 GPS (less than a year old. Thanks smile
Posted 08/29/2006 01:33AM | Edited 08/29/2006 01:37AM #1
Hello Robert!
Are you running in Alt-Az mode or Polar mode? The weight counterbalance systems could be different, depending on your configuration...
I have my Orion ED-80 Piggybacked on my 10" LX-200GPS, and use the Losmandy dovetail & rings system... a wonderful set up, but heavier than others since it is solid aluminum...
Here is a link to them... (not cheap, but some of the best)
http://www.losmandy.com/secondary.html
Remember that ATWB carries this stuff, and you might be able to get them at a discount price... so check this site for the parts you find at this link... wink
