Jay Messeroff
Lunar & Solar Transits
EM-11 & EM-200 How big are they?
Started by Hans Tucker, 09/05/2007 11:25AM
Posted 09/05/2007 11:25AM Opening Post
Hey readers,
I am trying to get a mental picture of the actual physical size and capacity of the EM-11 & EM-200 mounts but I have not ever seen either mount. Mounts I have seen that I can relate size are the G-11, HEQ-5 and EQ-6. Is the EM-200 more a kin to the size of a EQ-6 or the HEQ-5. How manageable is the EM-200. On the subject of the EM-11 would this be comparable to the Losmandy G-8. Is the weight capacity of the EM-11 18lbs as detailed in the Takahashi manual or more towards the 30lbs as specified on the Anacortes website. What are actual users of the EM-11 & EM-200 loading on these mounts for visual and imaging.
I am trying to decide on a light weight mount that can easily take my new FSQ-106ED and possibly my Mewlon 250S. Unfortunately the NJP is a physical challenge at times when you have spontaneous desire to go out observing.
Cheers,
Hans
Posted 09/05/2007 05:26PM #1
Hans
It's been a while since I owned a G11, but I'd say that the EM200 is roughly comparable in size,perhaps a bit lighter. I find it easier to move about than the G11 because the GEM head can be quickly removed from the tripod. Regarding capacity, the EM200 will easily handle the M250 and FSQ. I use heavy imaging equipment atop my EM 200 and it handles everything without any problems whatsoever. Quality wise, go with the EM200. It is a superb mount and a significant step up from the G11. If you're strictly a visual observer, either mount will keep you happy. If you're sure you'll be using an M250, go with the EM200 rather than the EM-11. You'll appreciate the extra capacity of the EM200.
Rob Mackie
Rob Mackie's attachment for post 116616
