EM-200 Owners
I've been following the thread (Tak Yahoo Users Group) on the EM-200 pier adapter and
thought I would show how I solved the EM-200 mount to any permanent
pier.
I first designed and built a very simple permanent pier out of 6
5/8" OD steel pipe, added an 18"X1/2" circular base with three
gussets and on top I welded on a 9"x1/2" plate. Welded everything
together, had it powder coated and J bolted it to a concrete base.
Pictures of these kinds of piers can be found anywhere. Total cost,
pier and cement (3/4 yard) about $500.00.
I drilled a 1/2" hole in the center of the top plate, now all you
need is an adapter with a similiar hole for any mount you may use.
For the last year I had a Meade Adapter for my GM8 mount. I now have
a custom made adapter for an EM-200 mount. A local machine shop made
the Black powder coated adapter (my actual cost was $130.00, but
they said it would be more for anymore, little more work than they
thought).
I have attached a photo, that will explain all.
The adapter is threaded to fit the Takahashi EM200 pier adapter on
the left (green top, black bottom).
Hope this gives those looking for an EM200 mounting solution some
ideas.
Brian Guerin
Carson City, NV
pier.
thought).
ideas.
Brian Guerin
Carson City, NV
