I have a Sky-90 on a Williams Ezy Touch mount and a FS-128 on an EM-200. I love both. Perfect combo of grab and go and heavy artillery. But to get more use out of my FS-128 I was thinking of the following long-termed changes. I do not do astrophotography.
1) Use the FS-128 with or without my Sky 90 on the Williams Alt-Azmuth. The FS-128 is about 16lbs, proably 18 or so with finder and clam. So technically this would work... top weight is 22 per side on the Williams, but technically and works well are frequenetly different.
2) Then get an FS-152 for my EM-200. I think the weight limit for the EMM is around 45Lbs and the 152 is about 28 lbs with clam. So since I don't load it with lots of cameras an piggy back scopes, this sounds like a great combo.
My FS-128 becomes a grab and go. And when the weather clears (Washington state... not often). I can haul out the big gun... a bigger one then now.
So, is this likely to work wonderfully, or have I not thought of something?
JD
JD
