Wizard Nebula
"Keitel Adapter" for FS-60C
Started by ivanong, 01/21/2005 03:37AM
Posted 01/21/2005 03:37AM Opening Post
Hi, does anyone know what it is? It is listed as a new product at ATWB.
Ivan
Posted 01/21/2005 04:05PM | Edited 01/21/2005 04:22PM #1
I have an idea
It bears my name
The new shorter FS-60c is great for visual and one can use a Binoviewer on it now. However when one wants to connect a Reducer/Corrector with a metal back distance of 72.3mm ( http://www.aajonahfish.com/measurements.htm ) there will not be enough focuser travel if you are at the correct distance. This adaptor, was made to fit between the Reducer/Corrector and scope, extending the lenght of the FS-60c. This enables the user to have enough travel distance in the focuser to move it properly.
Images of the Adaptor in use with the Fs60c and image train
http://www.aajonahfish.com/fs-60c.htm
In the enclosed image the part between the camera rotator and Reducer/corrector is the "keitel" adaptor. I had them put a diamond patter in the adaptor so your hands will not slip on it when you want to loosen it.
Hope I was clear with the above?
Mark
astroguy's attachment for post 87293
