james carter
North American Nebula NGC7000
maddening FS-128 first light
Started by mclemens, 11/24/2005 08:49AM
Posted 11/24/2005 08:49AM Opening Post
(I'm not angry at anything or anyone, dont read me wrong. Just a frustrating failed attempt at using a new scope.)
I rcvd a new FS128 "short version" from Astronomics today. I had called them up after ordering it and asked them if it would have the parts I needed to use the telescope when I received it. Was a 2" ocular adapter included? or not? I had bought an FS102 back in 2000 and I thought I needed to buy it separately.
Neither Anacortes or Astronomics could answer that question, were these 2" adapters included at some point to cause this to be unknown?
So, there is no 2" adapter. No problem, I can order one, not on Thanksgiving, but on Friday, for delivery on Monday. And also no problem, I've got a 1.25" diagonal and small eyepieces, I'll just use those!
Well, looks like the new "Short Version" is so short as to be unusable without extensions? Which are also.. not included? I could not reach focus without pulling my little diagonal out until I had left about 1/4" of its barrel in the telescopes clamp, and then pulling my eyepiece out until about 1/4" of its barrel was in the diagonals clamp. Is my scope missing a crucial, normally included piece? Or is this normal trouble for the new short version?
I almost always binovue, so I appreciate the extra in-focus, but it seems like I'm going to need some more parts to make this scope usable.
1) a 2" ocular adapter
2) Some (hopefully full diameter) focuser extensions. As a second best solution, I guess I could use a 2" extension tube like the front part of my Astro-Physics BARCON barlow?
So finally, my QUESTIONS:
(Q1) Is this normal, or, are there parts missing from my FS128 scope box? the 2" ocular adapter? the extension tubes to be usable at all even with 1.25" eyepieces?
(Q2) Are there full diameter 2.7" focuser extensions I can put between the drawtube and the (upcoming) 2" ocular adapter? Or, what do I use to get solid extension for 2" devices?
Thanks for any help! I sure could use it.
Mike Clemens
mclemens's attachment for post 28269
Posted 11/24/2005 09:52AM #1
Mike,
Have you tried looking at the Takahashi System Charts for the FS-102-128N 'Photo-Visual System' available on the Texas Nautical Repair website.
It looks like you do need a special type of adaptor.
Best of Luck
