Ghost of Cassiopeia
Mewlon 210 and M51 - semi "first light"
Started by ayiomamitis, 04/25/2009 01:01PM
Posted 04/25/2009 01:01PM Opening Post
Dear group,
Last night I finally had my chance to set the Mewlon 210 loose on the night sky. I collimated the optics about two weeks ago but the intervening weather did not allow for any sort of work under the starry sky.
Both the seeing and transparency were quite flaky last night with periods of very good seeing and transparency as well as the converse. To this end, I decided to forego my primary target of interest (NGC 4088 in UMa) and pursued some test exposures involving one of my favourite pair of interacting galaxies, namely M51 in CVn.
Since these galaxies beg for portrait framing, I set the camera with a 270-degree rotation from its "home position" so as to also have a really good guide star available for me to use. However, this is where I experienced my first disappointment, for the CCD camera (ST-10XME) was obstructing the view through the finderscope and which is placed on top of the telescope and in contrast to other manufacturers who allow for placement at 45 degrees to the left or right. I understand and appreciate having the finderscope atop the OTA so that it can also be used as a handle when transporting the OTA but it becomes useless when a CCD camera is placed in portrait mode.
Once everything was aligned 15 minutes later, I experienced my second disappointment. The Moonlight two-speed focuser impresses the user with its fine construction and sweet smooth movement when using the fine adjustment knob. However, there is a lot of play when the CCD's camera 2" nosepiece is inserted. For a moment I could not understand why my spikes (due to the vane) were duplicating on the computer screen but then I realized that it must be a flatness problem (ie. the camera not being square to the plane). To make matters worse, my optical alignment two weeks earlier did not consider such a potentially hidden problem.
After fiddling around with the securing of the CCD camera onto the Moonlight focuser, I was able to get it square but the focuser then started to roll on me. Tightening a couple of screws seem to fix this problem and I was finally in a position to start imaging.
Attached is my first result using the Mewlon 210. It is based on two hours total exposure time (12 10-min subs) taken at an image scale of 0.58"/pixel and which has been resampled to 50%. A DDP non-linear stretch was applied so as to compress the dynamic range and thereby allow a greater amount of detail to be presented simultaneously.
When aligning the optics two weeks ago, it was quite obvious they were razor sharp but the issue of flatness always remained at the back of my mind. The manual states an 18mm image circle for the Mewlon 210 at its native focal length of 2415 mm. Inspection of the attached image would seem to confirm this to be generally the case since the stars are very slightly deformed at the corners.
I run CCDInspector very quickly through some of the subs and the software suggests tilt as well as some misalignment for the optics. As a reference, I checked some test subs taken with my AP160 over the winter during adverse conditions and it is obvious that I still need to work on finetuning the alignment for the optics.
For my AP160, the tilt of the camera was 0.0", the optics were off by 0.1" and the flatness was reported to be around 7.5-7.8% (depending on the sub being used). From last night, I was getting a tilt of 0.8 to 1.1" for the camera (thanks to the Moonlight focuser), 8" for the alignment (or misalignment) of the optics and 24% for the field flatness.
It is obvious that I first must work on the camera being square before I tackle the issue of optical alignment. The Moonlight focuser uses three screws and a compression-style mechanism but it is not working as well as my AP160. Since the Mewlon is characterized with minor mirror shift during focusing (and refocusing), the Moonlight focuser did solve any such shift which would have occured otherwise.
Something I should also mention is the issue of temperature stability. I purposely stuck around for a few hours so as for the temperature to drop (it usually hits bottom around 3 AM local time) and I was impressed by the Mewlon. It is quite stable even with a fluctuation of four degrees in the ambient temperature and I suspect this is due to the open-tube design. As is always the case, I start preparing for each evening's session two hours earlier and which indirectly provides ample time for the tube to cooldown. With last night's problems due to the finderscope and Moonlight focuser, these two hours were further extended by around 45 minutes.
Anyway, last night's effort was more for testing the waters than anything else and which proved to be quite acceptable in lieu of the various problems encountered and various finetunings outstanding as a result.
Anthony.
ayiomamitis's attachment for post 46610
Posted 04/25/2009 09:04PM #1
I enjoyed the honest report. I think the picture looks pretty good! Martin
"In the beginner's mind there are many possibilities, but in the expert's there are few." Shunryu Suzuki[COLOR="Blue"][/COLOR]
Posted 04/26/2009 08:53PM #2
Hi Anthony!
Looking good! Great first light despite all the issues and challenges you faced!
As far as dealing with getting the camera square with the Moonlite, you may want to consider Moonlite's 2" Smooth Bore to T-thread adapter:
http://www.focuser.com/cgi-bin/dman.cgi?page=productdetail&plugin=dstore.cgi&product=2T-Adapter
They also have a similar adapter with SCT threads.
I believe the undercut in the SBIG nosepiece may be what is causing the tilt. I bought one of the smooth bore T-threaded adapter, and as far as I can see it is not contributing to any tilt in the image. To address the issue of potential slippage of the nosepiece from the drawtube, Moonlite also offers Allen-wrench-head screws that replace the thumbscrews for its focusers for a really tight fit without marring the nosepiece. These have been tested by Moonlite to loads of 50 pounds (almost 25 kilos) without slipping. I have this arrangement and have to say that so far I am satisfied (pending longer-term usage).
I originally did this for a Moonlite focuser that I adapter to a refractor (I didn't want to motorize the refractor's focuser). It worked so well on the refractor that I decided to give it a try on my Mewlon 210 as well (in fact, the Moonlite was purchased originally as a focuser for the Mewlon).
The Moonlite focuser I have is the version with the Robofocus-compatible stepper motor.
Eric
