Mewlon 250s Collimation
Started by reconair, 05/29/2008 04:36PM
Posted 05/29/2008 04:36PM Opening Post
I'm currently wrestling with collimating my Mewlon 250. I've spoken with Fred at TNR and he has walked me through the process (more or less), but there are still some things I don't understand. For instance, the push/pull sets used for adjusting secondary position -- What is the effect of turning the push screw anti-clockwise? Does it simply pull away from the secondary? In which case the pull screw would be turned clockwise to bring the secondary back to contact with the push screw. Is that right? And what is the effect of turning the pull screw anti-clockwise?
Fred, also mentioned that before any adjustment of the push/pull sets is done, you must first ensure the a third set of screws are snugged. This third set are supposed to be in position at 11-2-6 oclock positions on the secondary cell perpendicular to the push/pull sets. Are these screws familiar to any 250 owners? I can't seem to locate them. Fred says that they are 1.25mm hexscrews. The push/pulls are .9mm. Is Fred referring to the spidervane adjustments? I dunno, I'm perplexed.
Does anyone know of a link or might have a detailed description of collimating the 250s? Hopefully, with pictures? Fred says he's been meaning to sit down a write some up, but has yet to do so.
Scott Busby
A.K.A. Reconair
Carpe Noctum
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
- Ptolemy,c.150 AD
Posted 05/29/2008 04:56PM #1
Ferd asked you to call him with the scope in front of you this next time you speak with him.
He can answer your questions and you can follow his directions.
Art Ciampi
