james carter
North American Nebula NGC7000
Sky 90 v. Sky 90 II
Started by cbowman, 09/14/2006 12:02PM
Posted 09/14/2006 12:02PM Opening Post
Can someone tell me the difference between the Sky 90 and the Sky 90 II and when the Sky 90 II was introduced to the market? Thank you. Curtis
Posted 10/30/2006 02:12PM #1
I believe the Sky 90 II has re-design of lens mount, making possible user alignment of objective lens. This has proven to be highly successful. The short FL relative to the aperture makes the objective lens sensitive to correct alignment.
The Sky 90 II was introduced at least four years ago.
The Sky 90 II is on my wish list of great scopes!
Note also that William Optics has introduced a scope with 90 mm aperture and triplet lens for a "mere" $1300, which seems like quite a bargain. It uses S-FPL53 extra low dispersion Ohara glass, the best Fluorite-like glass available. [I have the WO 80 mm f/7 ED II triplet apo, which uses the "lesser" S-FPL51 glass. It is excellent!]
We live in great times when "optical perfection" ic both achievable and affordable!
Posted 02/26/2008 10:57PM #2
The "main" visible difference between the two is that the Sky90II has a sliding dew shield and a shorter tube, thus the "NSV" on the end. ...I think smile
Brian
