Affordable Planetary Eyepieces
Started by pjbilotta, 09/12/2002 04:06PM
Posted 09/12/2002 04:06PM Opening Post
While my 5mm ortho has performed admirably, I need something with longer eye relief in the 7-10mm range that will provide comparable sharpness and contrast for primarily planetary observing. Is there anything affordable ($50-$100) out there that might accomplish this for me other than high end Tele Vue, Ziess and others that I can't possibly afford?
Thanks for your recommendations.
Posted 09/12/2002 04:29PM #1
Yes, try the new Orion ED-2 at 9.5mm ($69) and/or Barlow a longer EP that has decent eye relief.
Posted 09/12/2002 09:22PM #2
My advice is to get a TeleVue 3x Barlow and
then a University Optics Ortho that works out
to whatever focal length you need. In my
experience this gives performance close to
high-end Pentax / Zeiss orthos, more eyerelief,
and at a small fraction of the cost. - John B.
Posted 09/12/2002 09:58PM #3
Check out the eyepiece reviews on http://www.excelsis.com
I have tried many eyepieces and tend to very much agree with the ratings there.
Posted 09/13/2002 01:42PM #4
Thank you all for some excellent advice. Quite a lively discussion.
It sounds like barlowing an already excellent planetary like an 7-9mm ortho or RKE may be the best solution for increased eye relief for those of us on a budget with fast scopes (mine's a 6" f/5). They lead to two additional questions . . .
Does anyone have any experience with the 5mm Ultrascopic versions that already have a barlow built in, yielding the eye relief of a 10mm. Does this perform better or worse than using a separate barlow.
And second . . . the best barlows for this application?
Thanks again!
Posted 09/18/2002 05:28PM #5
I would go with the high eye relief eyepieces from "Hands on optics" There cheap, have 20mm of relief, provide a good image, and are made by Anteres, I believe, at least that is what I was told on the phone, when I called them. All sizes also on ebay.
