My scope is powered by two 7AH batteries which will run the whole system (Argo Navis, Servocat, cooling fans, secondary dew heater) for roughly 2 nights of observing before they need recharging. I have an 85AH marine battery with a 150 watt inverter. If I wanted to charge the onboard scope batteries with the inverter powered by the marine battery how could I figure the efficiency. This would go from marine battery, to inverter, to the onboard 1.5AH battery charger, to the two 7AH onboard batteries. I would only really need to get 2 good full charges of the two 7 AH batteries, which in a perfectly efficient system would only drain the marine battery down to 57 AH, but I know that is not is not the real world case, I am going to try it later this month, just wondering what I could expect. I already have the marine battery and the inverter. I really dont want to buy an extra set of 7AH batteries or an expensive 21 watt solar charger, and I cannot use the marine battery to power the scope directly as the wire running from the battery would wrap around the scope as it slewed. TIA, Vince
Any electrical experts out there?
Started by vbert, 03/02/2004 03:31AM
Posted 03/02/2004 03:31AM
Opening Post
Posted 03/02/2004 05:21AM
#1
Hi Vincent,
Rough guess, I would say each system is around 75%, so a full trip 0.75 x 0.75 ~ 0.5, so ~50% (56?) total efficiency.
But trying it out should be fairly quick !
To actually measure the eff. would not be too bad, but you would need a clamp-on current probe to measure the AC current out of the inverter, and a DC current meter going into the inverter. If you have this equipment we can go into more detail.
Your inverter may actually spec. out the eff. in the manual somewhere. The charger manual would likely not give this kind of info.
ex-spurt
David Simons
ex-spurt
David Simons
Posted 03/03/2004 01:09AM
#2
Vince, I would not be quite as optimistic as David. I would use efficiencies of about 50 percent at these rates on a 150W inverter. You are putting 18W into the batteries, so the inverter is supplying on the order of 30-35 watts max. Note that you should not be drawing down these batterries to flat, otherwise thier life is severly cut short, on the order of tens of recharge cycles, not the hundreds one expects. Normally one should only discharge to 1/2 the rated AH before recharging.
Doug W.
Doug W.
Funding Member
