Ghost of Cassiopeia
Anyone Else Having trouble with Mars??
Started by Midnight Sun, 08/21/2003 06:14PM
Posted 08/21/2003 06:14PM Opening Post
Thought it was my scope out of Col.( Celestar 8" /TV Everbrite Dia..) but it is dialed right in. When Mars reaches it's highest point in the South/Southwest I start with a relatively low power (68x)EP, 30mm. 2" Apogee WideScan II. I get a Yellowish Orb. Increase the power with a UO 7mm. Ortho (290x) and I get a bigger Yellowish orb with the faintest hint on color variation towards the center of the planet. Could it just be "Bad Seeing" ? Almost like trying to focus Venus clearly..John Meiners, Astoria, OR
Posted 08/21/2003 06:22PM #1
What type scope is it? Did you give it enough time to cool off?
Posted 08/21/2003 06:45PM #2
John,
I have viewed Mars the past two nights from portland. Views were very so-so. I was able to see ice cap and dark rim around the ice but not sharp at all. This was with a 8 dob from my driveway. The smoke from fires in central oregon have caused incredible sky glow from the light reflections toward the east. Around august 5th in central oregon I had killer views in my 18 inch dob, using celestron variable polarizer. I held the polarizer up to Mars naked eye, dialed down to dim, then placed on the eye piece. Hopefully smoke will clear for Oregon Starparty next week.
Posted 08/21/2003 06:50PM #3
Here in Los Angeles, it was hot for the last two weeks, and I wasn't even able to go past 150X on Mars. Only the last few nights has it finally gotten better - I was able to use 250X-300X last night, which I would consider average seeing. Summer can be tough on seeing, since heat rises all night off rooftops and concrete that soaked up the sun's rays all day.
-Jake
Posted 08/21/2003 07:04PM #4
I'm Viewing from Chatham Ont Canada About 45 minutes east of Detroit Michigan.
I'm having the same thing.... a Week or two ago it was easy to see detail.... The last few nights it's been tedious... The cap is easy but I have to look really hard for detail...
This applies for both the Orion st100 refractor and the Orion xt10 dob..... I thought it was just me but am kind of relieved to hear others are having problems too..
My biggest problem is ghosting.... I'm using a light shield, have flocked the inside of the telescope, have flocked the focuser and still I have ghosting in the xt10. I assume it is because the planet is getting so bright as it wasn't like this a few weeks back.
Mark V
Posted 08/21/2003 07:40PM #5
Last Saturday the seeing was similar to yours, no real details like the week before.
I am in So. California.
Posted 08/22/2003 03:06PM #6
John,
I live in an extremely humid enviornment in Florida. As such, I seemed to be having the same problem as you from time to time while using my binoviewers. Guess what? I discovered that the heat from my eye was causing some condensation to form on the EP's when I got in tight. How weird is that.
Paul Atkinson
AstroProProducts.com
