SH2-157_Seestar_S30_Pro
Bino focusing wheel rubber cover
Started by Cookieman, 04/05/2012 12:53PM
Posted 04/05/2012 12:53PM Opening Post
Does any one know where i can obtain the rubber grib material that is used on focus wheel of binoculars.
Seems to be a generic item that is glude onto focuser wheel.
Thank for any help.
Tom Nigrelli
Posted 04/05/2012 08:00PM #1
Thank for any help.
Tom Nigrelli
It is probably liquid latex. The object to be coated can be dipped into it with multiple layers to build it up. Be sure to clean any metal parts with hot water and soap and thoroughly drying followed by acetone before applying the latex. Do NOT use acetone on most plastics! Once you start applying the latex, let it dry between coats. Drying time varies depending on humidity, temperature and brand/viscosity/thickness of applied layer.
