CI-700..which computer works best?
Started by ttolla, 02/01/2006 06:52PM
Posted 02/01/2006 06:52PM Opening Post
Hi all,
As I wait for my CI-700 to be shipped to me, I value your opinions on a encoder/computer combo. Argo-Navis....maybe ? I've been looking at the SkyWalker but realized setting this mount up with go-to is out of my budget. I'll settle on push-to for now (I'll spend the extra $$$ on the gym membership 8) ).
Thanks for your input
Tom T
Tom T.
Guilford, CT smile
Posted 02/02/2006 02:06AM #1
Tom, I recently purchased a CI-700 that came with the Celestron encoder adapter and computer. It has 4000 tic encoders and the computer is almost identical to the JMI NGC-MAX.
I have been extremely pleased with this setup.
I calibrated the polar scope by doing a drift align and then zeroed the polar scope to polaris after getting an accurate printout of the correct location from Polar 203. From then on, I do a polar align, then a one star align, as if it was a permanant mounted EQ. Every object I "push to" is always in the center of the fov, even with a higher power ep.
Unfortunately the CI-700 encoder setup is no longer available from Celestron. But I have seen them here on AM several times in recent months.
Once you get the encoders, just about any of the computers will work fine. Some folks prefer the Sky Commanders, some the JMI or NGC units. All will work well once you become familiar with them.
Good luck, and enjoy the CI-700. I believe it is one of the better mounts out there, still.
Walt
Posted 02/03/2006 07:02PM | Edited 02/03/2006 10:19PM #2
I have 4096 tic encoder geared 2:1 for 8192 tics. These are mounted with JMI brackets. I replaced the warped plastic gears on the encoders with aluminum ones. I have the AAM and a Sky Wizard that are both "Tangent boxes". I have also used the Sky Commander with the CI-700. The pointing accuracy is very good putting the object almost dead center in the field. I like "Push To" operation just as much as full GOTO and it is more reliable. You also get to participate in locating those deep sky objects. 8)
John
ccdfreak's attachment for post 100540
John
CCD-Freak
WD5IKX
