I know this has been discussed before, but tis easier this way. I just received my "slab" of dark, closed-cell foam. My plan is to place most EPs on their side typically like Floyd has shown in the past. My question is, what is the best way to dissect the foam. Do you cut all the way through then wafer the foam for the bottom. Or are there other ways to make a profiled cut. Also, what are the best tools? My problem is that you really only get one chance at a hole and it would be nice to get it right the first time. Also the plan is to mount a few of the smaller 1.25 EPs vertical to save space. My fabricated hole cutter from a serated film tube seems to work well as does the serated cap from an "Edge" shaving foam can. Hear tell that hole cutting saws are also OK. Any help will be appreciated.
I Yam What I Yam!
