Here is the link: www.pbase.com/eagle92395/astro_pics
Here is the mount that I designed and made in a few days. When I got the ED80, the small EQ mount that was with it needed to go. For one, I hate EQ mounts for visual use, and this one would make you sick trying to look at anything. The shakes and irritating motions were enough to make me rip the mount apart and make a new one. Here are some of my design criteria:
1. The mount should be alt-az and very sturdy
2. Needs to be very easy to use
3. I need to be able to move it easily in a Camry along with a LX200, eyepiece case, battery...etc etc.
4. Needs to have a good range of balance... my 32mm 84" FOV and Meade 14mm UWA are huge eyepieces and need to work well with this.
5. Needs to be cheaper than what I can buy for $300
6. Needs to be "sexy", I can't have this great scope on some crappy little mount can I???
After some thought and a lot of web surfing, I decided that none of the mounts I'd seen so far answered all of my needs.
As you can see, the scope is held about 12" off the top of the tripod. This serves THREE purposes, it elevates the scope (DUH!) and it also allows the scope to point to zenith without bumping the tripod. Having the arms extend upwards instead of straight back also help to balance the azimuth axis so that the motion is smoooooooth!
