Equatorial mount for a C925
Started by SunSpot51, 06/15/2005 01:51AM
Posted 06/15/2005 01:51AM Opening Post
Hi,
I am thinking about equatorially mounting my C925. I prefer not to use a wedge (personal reasons). I am pricing CGE mounts, but would research other options. I'm sure many of you have much more experience than me. Any suggestions, and what would I need to buy in addition to your suggestion to make it work (dovetail, Go-to, etc).
Thanks!!
Paul Maxson
Paul Maxson
http://www.sunspot51.com
Posted 06/15/2005 02:25AM #1
I'll second that. I have a C9.25 on an Orion Atlas and it holds like a rock even with a Stellarvue Nighthawk piggybacked. But Paul, please tell us what you plan on doing with this mount. The Orion Atlas doesn't hold up to the CGE for astrophotography, although it can be done. Then again your talking about a huge difference in price. It all depends on what you would like to do with the mount and how much your budget will allow. I know I was on a budget when I purchased the Atlas.
Other mounts that would hold well are the Losmandy G-11, the new Synta EQ6 SkyScan and maybe the Takahashi EM-11 or Astrophysics 900.
Clear skies,
Jay Emirzian
Posted 06/15/2005 03:43AM #2
I've got mine on a G-11 by Losmandy
Posted 06/15/2005 01:48PM #3
CI-700. Very Steady and tracks well.
Posted 06/15/2005 02:12PM | Edited 06/15/2005 02:13PM #4
Paul,
I have a C9.25". I started out with a Vixen Sphinx. This mount tracked very nice especially under accurate drift alignement and GOTO was completely effortless with the C9.25". My problem was focusing when doing webcam imaging of the planets. Every touch of the focuser induced long lasting vibrations (>4 to 5 sec). The mount was not up to the job. I used a very stable Astrosky tripod and that did not eliminate the issue completely. For long exposure imaging of DSOs, a mount of this class would be susceptible to wind and any such disturbances. I had a GP-DX earlier and that was just about the same or even worse. I suspect a GM-8 and CG-5 will also be in this class.
Then I got a Tak EM-200 and it was money very well spent. I was hoping to find a AP 900 but timing did not coincide. With the Tak, focusing-induced vibrations were less than 0.5 sec. I think something in this class would be a minimum for serious use of the C9.25". I guess a CGE would work great here, or a G-11. Good luck!
Ivan
Posted 06/15/2005 04:56PM #5
I am currently using a C9.25 on a Losmandy GM8 (non-Gemini goto drive) for planetary webcam imaging.
My GM8 has a G-11 Saddle Plate, a polar scope and the standard tripod. The tripod is more stable at minimum height, but it makes using the polar scope a real, literal, pain in the neck. The current focuser is a JMI NGF-S so focus bounce is not a problem.
I have done some half-decent images with this setup, though nothing to compare to your stuff. Here's about the best I've done:
http://www.mnastro.org/forums/album_page.php?pic_id=123
All that being said, I feel that this setup is undermounted and hopefully will be upgrading to a G-11 Gemini soon.
The trouble ain't that there is too many fools, but that the lightning ain't distributed right. [Mark Twain]
Bill Bynum
Posted 06/15/2005 07:49PM #6
Paul,
I think Tim is right on the mark. For what you would like to do and for the money, the CI-700 would be a good choice. Good suggestion Tim!!
Jay
